1999 Ford Contour
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
AIRGYPIES
i have i 1999 ford contour. About every two week of normal driving the battery light comes on and then some time after the car just dies. The problem is intermittent . I had the battery, and altenator tested and everything tested good.. I dont know where to go from here..
Oct 8, 2008 at 6:08 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect the alternator
its mostly charging but not enough to keep the battery full or bad diode inside the alternator causing a draw back draining the battery
and or battery small not big enough for the car
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 15, 2008 at 1:47 PM
