1998 Ford Contour transmission won't go when in drive
12,000 MILES • 4 CYL • FWD • AUTOMATIC
RHAYES1980
I have a 1998 contour with about 120,00 miles, just the other day i drove it to work and everything was fine. When I left to go home it would barely go when I put into drive, so I downshifted into 2nd gear and it proceeded to go then I shifted back to drive when the rpm's got high enuff, that worked for awhile now it won't even go in the lower gears. If I get the vehicle to actually to accelerate to higher gears it goes just fine. Does anyone have any ideas.
thanks
Apr 22, 2008 at 3:29 PM
  • 31,937 POSTS
Hi there,
First make sure the fluid level is correct, if that is OK, you will have to get a transmission shop to run a pressure test on the box to check shift pressures, this may well be a faulty valve in the transmission valve body.
Mark (mhpautos)
Apr 22, 2008 at 6:49 PM
TUNERBOY313
I'm having the same problem and it happened in the same scenario... but my 2nd and 1st gear work but Drive will barely pull unless I pull off in 2nd then switch to drive.. could it be the same issue?
Jun 24, 2008 at 7:19 AM
  • 31,937 POSTS
Hi there,
you could have the same or a similar issue going on, i would still get it seen to by a trans tech, as there will not be very much that you can do your self.
mark (mhpautos)
Jun 25, 2008 at 10:32 PM
