1998 Ford Contour temp sender
MOA1405
Engine Cooling problem
1998 Ford Contour 6 cyl Front Wheel Drive Automatic
i have to put on a after market water temp gauge . a friend of mine kid broke the water pump belt and ran it hot till motor stoped. i was surprised but i got it running. but temp gauge is stuck over pass hot. can you tell me where the temp sender is so i know where to look not much room and im a big guy
thanks
Jul 13, 2009 at 5:07 AM
  • 75,988 POSTS
The engine coolant temperature sensor is located upper rear of engine. See item no.21 below
https://images.2carpros.com/forum/automotive_pictures/12900_ect_sensor_2.jpg
Jul 13, 2009 at 6:51 AM
