1998 Ford Contour Squealing under hood
130,000 MILES • 6 CYL • FWD • AUTOMATIC
HOLLYGB
My 98 Contour has recently developed a squeal under the hood as the engine warms. The coolant light is constantly on even though the coolant level is good. I have also recently noticed a slow loss of coolant. The water pump in the car is new, replaced only 6 months ago. It hasn't been overheating, but the temperature gauge went up slightly today. A friend looked at the car and said he thinks the driver's side fan assembly has seized. Could that be the problem, or is there something else I should look at?
Jun 4, 2008 at 12:08 PM
  • 31,937 POSTS
Hi there,
get the cooling system pressure tested, this will help locate any external coolant leak, the squeal may well be a faulty drive belt, ask your mechanic to inspect it for you.
Mark (mhpautos)
Jun 4, 2008 at 2:40 PM
