1998 Ford Contour Slipping and will not shift into OD
1998 FORD CONTOUR
162,000 MILES • 4 CYL • FWD • AUTOMATIC
DAENGMEI
There is very rough shifting into 2nd gear...very high rpm then after shift very low rpm. Transmission will not shift into OD and the dashboard OD ON/OFF indicator light begins blinking after only a few miles driving. Transmission slips when downshifting if I use too much fuel pedel force. I checked the fluid level (after 20 miles) and it was within the bottom 1/4 of the marks. There was darkening and a burnt smell. I have some rebuild experience with other engine components and have installed/removed both rear wheel and front wheel drive transmissions. I am confident enough that I would use a rebuild kit if the necessary speciality tools are reasonable to acquire.
Dec 29, 2008 at 2:01 PM
DAENGMEI
about a 95 Contour, nearly same symptoms. Range sensor, sounds reasonable. Sorry to not have read further before posting the question. Any other info? I will change the oil. Thanks.
Dec 29, 2008 at 2:33 PM
