1998 Ford Contour rpms
150,000 MILES • 6 CYL • FWD • AUTOMATIC
JACKH0L3
  • 5 POSTS
the car runs smoothly up til speeds reach 55+ or so
sometimes (and only sometimes) then the RPMs will raise, and the car feels the way it does when it shifts hard, then the RPMs will drop back to normal
and once the car red lined randomly while i was on cruise control, so i hit the brake.
also, someone had suggested maybe it was my Overdrive, but i turned that off while i was driving today, and the car still performed poorly
i think this is a transmission problem, but im not positive
Oct 14, 2008 at 1:15 PM
BMRFIXIT
  • 19,053 POSTS
Check tranny fluid
scan for tranny codes
over drive light blinking !!!
suspect internal tranny failure
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 15, 2008 at 1:04 PM
JACKH0L3
  • 5 POSTS
ive checked tranny fluid. its fine. i dont ever see the OD light change. its always on. so iguess ill have to get a friend check the tranny code for me.
thanks so much!
Oct 16, 2008 at 4:27 AM
JACKH0L3
  • 5 POSTS
ended up being that my torque converter was the problem
Oct 26, 2008 at 4:21 PM
