1995 Ford Contour Revving While in Park
130,000 MILES • 4 CYL • FWD • AUTOMATIC
HYPERION
Just recently my car started to rev up while in park. It does it when the car first starts up and after driving for awhile and I put it back in park. It used to shake quite consistently while idling at a light but it no longer does that because of the constant revving.
Reading online I saw that it might possibly be a dirty IAC valve. Any ideas? Thanks!
Mar 12, 2008 at 4:55 PM
MASTER TECH DAN
  • 83 POSTS
the idle air valve is probly no good and also clean the throttle plate so the air flow is correct
Mar 12, 2008 at 5:23 PM
MERLIN2021
  • 17,250 POSTS
Also is the check engine light on? First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
Check the throttle cable, and throttle for binding..
Mar 13, 2008 at 4:47 AM
