1998 Ford Contour r/p boot leak
115,000 MILES • 6 CYL • FWD • AUTOMATIC
RDINLE
I have a 1998 ford contour that is filling the boot between the r/p and tie rod end. this model has a fluid tube the insets into a fitting on the boot. Is the boot supposed to fill with fluid? Cuz if so it's full and flowing out the boot end ( drivers side only). HELP.
Aug 28, 2008 at 6:45 PM
  • 31,937 POSTS
Hi there, the boot No 6 in the pic is basically a dust boot to protect the steering rack. if this boot is filling with oil there is a failed internal seal that is not normally serviced on the car, the rack will have to be removed to repair this problem. Mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_38.jpg
Aug 28, 2008 at 8:04 PM
