1998 Ford Contour Replacing engine
LILNATEHAT
Engine Mechanical problem
1998 Ford Contour 4 cyl Two Wheel Drive 150,00 miles
I have a 1998 ford contour with a 4 cyl. dohc engine that is a vin 3 that is bad. Can I replace it with an engine from a 2000 model contour, 4 cyl. dohc, vin 3? Are they interchangeable?
Thank You
Apr 21, 2010 at 11:43 AM
  • 110,248 POSTS
We recommend staying with direct fit parts. Chances are there will be sensors / locations... that are different.
May 1, 2010 at 8:37 AM
