1998 Ford Contour rear control arm
JACOBDOSS
Suspension problem
1998 Ford Contour 6 cyl Front Wheel Drive Automatic
Need to know how to change rear control arms on a 98 controur.......... i have got the inner nut off but cannot get the little lock washer off to get the bolt out.... please help
Dec 14, 2009 at 9:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Retaining rings have a split where they may be accessed to expand it enough to fit over the bolt and then be slid off . Some retainig rings have a tab that protrudes above the ring groove and can be accessed with needle-nosed pliers and opened using a twisting motion and then removed by sliding off.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1314.jpg
Dec 21, 2009 at 12:58 PM
