1998 Ford Contour lower Control arm
1998 FORD CONTOUR
TONZIE
Suspension problem
1998 Ford Contour 4 cyl Front Wheel Drive Automatic
1 ball joint is damaged,how to replace ,passenger side,
Jun 28, 2009 at 4:07 AM
BMRFIXIT
  • 19,053 POSTS
Using a .118" (3 mm) drill bit, drill a pilot hole through each rivet. Change to a .354" (9 mm) drill bit and drill holes to a depth of .472" (12 mm). Using a .275-.314" (7-8 mm) diameter punch remove rivets. Remove ball joint
Jul 3, 2009 at 10:25 PM
