1998 Ford Contour how to fix
1998 FORD CONTOUR
KENNYCHAFE
  • 7 POSTS
1998 Ford Contour
How do you fix the temperature gague on the dashboard.I think the sensor might be gone because the temperature gague is not reading the temperature.
Jan 18, 2009 at 4:12 AM
BMRFIXIT
  • 19,053 POSTS
Locate the sending switch at the engine side and check its connector and wire
ground the wire if gauge go all the way to high suspect a bad unit
If heating quality is poor
remove and replace the thermostat
Jan 18, 2009 at 4:20 AM
KENNYCHAFE
  • 7 POSTS
Could you send me a diagrahm to show me where to find the sensor to show me what you were talking about.
Jan 18, 2009 at 4:25 AM
BMRFIXIT
  • 19,053 POSTS
what do u have for engine size
Jan 18, 2009 at 4:26 AM
KENNYCHAFE
  • 7 POSTS
The size of the motar is 2.0L 16v zetec vct.
Jan 19, 2009 at 9:30 AM
KENNYCHAFE
  • 7 POSTS
The size of the motar is 2.0L ZETEC VCT.
Jan 19, 2009 at 9:36 AM
BMRFIXIT
  • 19,053 POSTS
check around the coil area and thermostat housing
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_163.jpg
Jan 19, 2009 at 10:38 AM
