Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Contour
Engine Cooling
Water Pump
Replace/Remove
1998 Ford Contour Heat
1998 FORD CONTOUR
98,000 MILES • 4 CYL • FWD • AUTOMATIC
DISOKA
MEMBER
1 POST
Changed the water pump and now there is no heat. The engine does heat up, not over heat. What could be the problem
Mar 15, 2010 at 11:46 AM
Experienced Mechanic
Try bleeding it could be air in it don't work get it block and pressure tested
Mar 15, 2010 at 8:34 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
