Fuel Pump Relay Location ?
RACHEL.WILLIS09
Where is the fuel pump relay located?
Jun 4, 2009 at 4:02 AM
SQM
  • 6,383 POSTS
The fuel pump relay is located in the fuse block under the hood.
I have attached the diagram (see below) for that fuse panel. It should be number K4.
You might find this article helpful:
https://youtu.be/Hlna_kUt7As
Jul 21, 2021 at 4:07 AM
