1998 Ford Contour fuel problems
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
BECKYMILES
car is not getting any fuel to carborator. Checked fuel line under hood. nothing.
replaced fuel pump, fuel filter, and checked reset button on inside door panel, but it was pushed in.
not sure if the relay switch is bad. This is my friends car. Not sure what else it could be. There was no holes in the fuel sock when we replaced pump.
May 24, 2010 at 10:53 AM
  • 75,988 POSTS
Check and test the fuel pump fuse and fuel pump relay
May 24, 2010 at 3:40 PM
