Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Contour
Drivetrain
Wheel Bearing
Replace/Remove
1998 Ford Contour front wheel bearings
1998 FORD CONTOUR
160,000 MILES • 6 CYL • FWD • MANUAL
CLAMBERT36
MEMBER
1 POST
need to replace front wheel bearings. what is the easiest way to get to them?
Mar 28, 2008 at 7:22 AM
BMRFIXIT
Experienced Mechanic
What you have is a press in bearing you need a press to remove it and to install the new one in good luck
Mar 28, 2008 at 9:43 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
