1998 Ford Contour CRUISE CONTROL
110,000 MILES • 6 CYL • FWD • MANUAL
DMCGEE
  • 5 POSTS
When the cruise control is on and I hit a bump in the road the cruise control will shut off. I can put my foot under the brake pedal and put slight pressure on it and the cruise control will stay on. I have replaced the brake pedal switch but the control will still shut off with a bump. Any ideas????
Nov 7, 2010 at 11:42 PM
WRENCHTECH
  • 20,760 POSTS
It sounds like the switch is out of adjustment .
Deactivator Switch Adjustment
1. Reset the switch.
1 Pull the switch plunger out to its full extent.
2 Fully depress the brake pedal.
3 Install the switch.
4 Slowly release the brake pedal.
Nov 8, 2010 at 12:00 AM
