1998 Ford Contour car dies while turning, or just won't sta
RHONDA GULARTE
  • 1998 FORD CONTOUR
  • 4 CYL
  • FWD
  • MANUAL
  • 125,000 MILES
While driving my car, and I'm making a sharp turn, my car will just die. Sometimes it will start right up. Sometimes it will not start. Also, there are times when the car won't start. I replaced by battery, I have replaced the spark plugs, fuel pump, altenator, put in clean fuel filter, have replaced the clutch slave. Other than this "starting" problem the car now works and sounds great. Could this problem be electrical or a bad sensor?
Wednesday, April 21st, 2010 AT 3:05 PM
  • 109,885 POSTS
It sounds electrical. Has the check engine light ever come on? In this case, you may have to have an onboard computer hooked up to check what is happening when it dies.
Saturday, May 1st, 2010 AT 3:41 PM
