1998 Ford Contour accelerates on own
ANGELWING327
1998 Ford Contour 6 cyl Automatic 111, miles
Two problems here: This car has 111,000 miles on it. Feels like throttle stuck, misses once in a while and will not alllow me to put gas in tank. Keeps clicking off even though my husband checked the fuel line and there are no visible signs of kinking. I swear this car is haunted and driving me crazy! This car just wants to drive itself!
May 12, 2008 at 11:39 AM
BLACKOP555
  • 10,386 POSTS
if it feels like the throttle is stuck try lubing it with some wd-40.
for the fuel pump shutting off constantly i would check the vapor check valve on the tank, as long with the charcoal canister and all the vapor lines.
May 12, 2008 at 12:54 PM
ANGELWING327
[quote:c409ff9254="blackop555"]if it feels like the throttle is stuck try lubing it with some wd-40.
for the fuel pump shutting off constantly i would check the vapor check valve on the tank, as long with the charcoal canister and all the vapor lines.[/quote:c409ff9254]
May 12, 2008 at 1:32 PM
BLACKOP555
  • 10,386 POSTS
yes angel?
May 12, 2008 at 1:43 PM
