1998 Ford contour 2.5 lx hesitating and bucking
ECKOJOE
Hello I just receintly purchased a 1998 contour lx 2.5 v6 with auto transmission and for the first couple of days it drove perfect and then when I was driving on the highway it felt like the car had died, then the front end bucked like 2 or 3 times then it went right back into gear and off I went it has done this every time I start the car up and started driving at low speeds city driving or at high speeds highway driving, it does it if there is a full tank of gas or almost on empty, I have been reading up on this issue and it seems like there is no clear answer on how to fix the issue and I really don't want to dump a bunch of money into the car and thoughts on this issue would be greatly appreciated.
Thanks :D
Jun 26, 2007 at 4:20 AM
SHELBYGT
  • 56 POSTS
its your motor mounts if your lazy like me you will have to spend alot of money because when one goes bad the it creates a bucking that leads to the rest of the motor mounts so as soon as you know it you have to replace all of the motor mounts. yeah it is not what kind of gas you put in it its the motor mounts
Jul 18, 2007 at 5:57 AM
