1998 Ford Contour
NEHIYO
  • 1998 FORD CONTOUR
Noises problem
1998 Ford Contour 6 cyl Front Wheel Drive Automatic
when key is out of ignition fuel pump still runs and relays are clicking. What is the problem?
Saturday, January 3rd, 2009 AT 3:42 PM
DAVE H
  • 13,384 POSTS
Try checking or replacing the ignition switch
IGNITION SWITCH
Check resistance between specified terminals with switch in each position. See IGNITION SWITCH RESISTANCE table. See Fig. 2. If resistance is not as specified, replace ignition switch.
Switch Position. Between Terminals No. Resistance
Off.1 & All Other Terminals.(1)
Accessory.1 & 8.(2)
Run.1 & 4.(2)
Start.1 & 5.(2)
(1)Resistance should be greater than 10,000 ohms.
(2)Resistance should be less than 5 ohms.
Saturday, January 3rd, 2009 AT 3:51 PM
