1997 Ford Contour Wont run normal
1997 FORD CONTOUR
160,000 MILES • 4 CYL • FWD • AUTOMATIC
DEXTERJUNK
Ok it will start and idle but if u put it into gear and try to pull out it stalls and it only runs if the air intake isnt on the the throttle body. what could it be????
Jun 10, 2010 at 12:13 PM
Clean the mass airflow sensor and test the throttle position sensor
Jun 10, 2010 at 12:15 PM
