1997 Ford Contour will notfire
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
MICHAEL LEONARD 62422
replace engine run about 1minute now will not start replace coil crane sencer , cam sencer wireing harnses had pcm check still no fire is coming out coil fire is getting there to ciol but not coming out new plugs and wire all ground wire are conact to frame and moter check fusees replace relays and fule pump shut off swicth help
Feb 28, 2010 at 1:07 PM
SERVICE WRITER
  • 9,123 POSTS
IS the fuel pressure good?
The wiring harness right next to the ignition module bracket may rub thru the insulation and cause a no start. Pull up the ign. module brackett and check the harness for rubbing the back side of the bracket where the nut that holds the module on is welded on.
Check that first and post back.
Couple notes on this car:
Also check for the coolant temp sensor and crank sensor connectors being put it opposite. They are exactly the same and are very close to each other. Although since it did run, this may not apply.
These are common for flywheels cracking and hitting the cranksensor.
Feb 28, 2010 at 9:37 PM
check wireing on 1997 ford contorl check plugs on crane sensor and temp sensor are correct whatis next
Mar 1, 2010 at 2:58 PM
SERVICE WRITER
  • 9,123 POSTS
What codes are stored in the computer?
Are the plugs gapped right?
Did you pull any back out to inspect conditions?
I hope you didn't use bosch plugs.
Recheck Fuse no. 4 goes to the pcm power relay and to the ignition coil. Be sure it is good.
Be sure the crank sensor is not damaged.
Inspect it.
Less likely, but may be worth verifying:
Check the timing to make sure it is still in time.
Compression test to make sure cylinders are still compressing
Check the fuel pressure to be sure it is in spec.
Mar 2, 2010 at 12:17 AM
a friend of pull a code will did not under stand the code is internal control module keep alive memory(kAm) error.where is this and do we fix it? is this the pcm somebody said that we would have to get it flash . to do this would we just carry the pcm or the whole car thank you.
Mar 18, 2010 at 4:04 PM
SERVICE WRITER
  • 9,123 POSTS
what are the code numbers?
Mar 18, 2010 at 10:42 PM
the code was 0603 ya have great help thank you
Mar 19, 2010 at 2:49 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_a2_2.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_a21_1.jpg
Mar 19, 2010 at 6:08 AM
SERVICE WRITER
  • 9,123 POSTS
I sent this to your email, check your spam folder if it didn't appear.
Mar 20, 2010 at 12:32 AM
