1997 Ford Contour Transmission slipping--dropping in &
BASSDRUM66
  • 1997 FORD CONTOUR
  • 4 CYL
  • FWD
  • 132,000 MILES
Transmission ok while cold. After about 10-12 miles starts jumping in and out of gear. Turning off OD helps some, but it will still go in and out, sometime "slamming" back in gear. Do to age and mileage, I feel repacement not practical. Don't know if there is a fixable cure.
Thursday, June 24th, 2010 AT 10:20 AM
DAVE H
  • 13,384 POSTS
Hello. Thanks for the donation.
Sounds like you have a pressure leakage when trans get hot (seals expand). It will only get worse as time goes on i'm afraid your best option is a rebuild or replacement
Monday, June 28th, 2010 AT 4:56 AM
