1997 Ford Contour Transmission not shifting into overdrive
FUZZFLYR
Transmission problem
1997 Ford Contour 4 cyl Front Wheel Drive Automatic
The transmission is slow to upshift from 2nd to 3rd, and will not shift into overdrive. at about 62 mph, the OD light starts flashing (almost like limp-in mode).
OD light resets after shutdown, and speedo works fine. Any thoughts?
Jul 3, 2009 at 11:55 AM
BMRFIXIT
  • 19,053 POSTS
Internal tranny issue
check for tranny codes
check make sure tranny fluid up to level
Jul 3, 2009 at 9:59 PM
TRANSMAN1
  • 29 POSTS
Are you sure its shifting to second? sounds like 2-4 band broken and it is shift 1-3 and no second or fourth.
Jan 6, 2010 at 11:10 AM
