HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Contour
Engine
Timing Belt
Replace/Remove
1997 Ford Contour Timing Belt Reset
RBROWN77
MEMBER
1997 FORD CONTOUR
1997 Ford Contour 4 cyl Front Wheel Drive Automatic
I just replaced my waterpump and need my timing reset. How do I reset that and what special tools do I need?
Friday, September 19th, 2008 AT 3:10 PM
OBXAUTOMEDIC
MECHANIC
You will need a cam shaft alignment tool.....
Here is the alignment for the crank shaft...
Friday, September 19th, 2008 AT 3:27 PM
Please
login
or
register
to post a reply.
Related Timing Belt Replace/Remove Content
Timing Belt Replacement Marks?
I Need Step By Step Instructions To Replace The Timing Belt On My 98 Ford Contour It Is 2 Wheel Drive Automatic W/ 4 Cylinder Twin Cam...
Asked by
berthas1man
2 IMAGES
1998
FORD CONTOUR
I, Ve Had Interminnit Heat From My Heater, Car Got...
I, Ve Had Interminnit Heat From My Heater, Car Got Warm All Of The Sudden, Noticed The Drive Belt Was Dammaged By Something From The Road...
Asked by
Anonymous
1 IMAGE
1996
FORD CONTOUR
Installing Timming Belt
2000 Contour 2.2 Instruction How To Install Timming Belt
Asked by
grwrightsr
3 IMAGES
2000
FORD CONTOUR
1999 Ford Contour
I Had Just Replaced Timing Belt The Car Ran Perfect For About A Week Now I Have A Misfire On All Cylinders And A Bank 1 Code P0300 P0301 Any...
Asked by
JASON1984
1999
FORD CONTOUR
1996 Ford Contour Problems With My Fan
It Seems When I Start My Car My Fan Turns On To Cool The Engine. When The Engine Hasnt Been Running For Hours. Could It Be The Thermostat...
Asked by
rafi4321
1996
FORD CONTOUR
VIEW MORE
How to fix an engine that wont start
Serpentine Belt Replacement Chevrolet Tahoe
Serpentine Belt Replacement Ford Contour
