HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Contour
Engine
Symptoms
Not Running
1997 Ford Contour runs but won't Move
ANNDAVENPORT32
MEMBER
1997 FORD CONTOUR
Engine Performance problem
1997 Ford Contour 6 cyl Two Wheel Drive Automatic
hello. I can start my car but when I put it in any gears, it will just make a loud ribbum but will not move
Wednesday, April 8th, 2009 AT 4:09 PM
BMRFIXIT
MECHANIC
Sounds as you have a broken axle
check front axles
let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Wednesday, April 8th, 2009 AT 6:35 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
97 Ford Contour Starting Problems
97 Ford Contour Sport, 6 Cylinder 84,000 Miles Hi, About 3 Weeks Ago, As I Was Driving My Car, I Slowed Down To Stop At An...
Asked by
tsurera
1 ANSWER
1997
FORD CONTOUR
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1997 Ford Contour Only Starts When Cold
I'm Having A Mysterious Problem With My Car. It Starts Normally In The Morning But Then After Driving Around For A Short Period Of Time And...
Asked by
pvpatel84
1997
FORD CONTOUR
1997 Ford Contour Car Runs A Second Or Two And Stops
My 97 Contour Has Now On 2 Occasions, 3 Weeks Apart, Refused To Run More Than A Second Or Two Before Stopping. I Tried To Start It Several...
Asked by
talbotbugman
1 ANSWER
1997
FORD CONTOUR
1997 Ford Contour
Car Wont Restart After It Is Shut Down After Running For 20 To 30 Minutes, And Sitting For 15 + Minutes
Asked by
papalee
1 ANSWER
1997
FORD CONTOUR
Engine Not Running
My Car Has Recently Started Stalling Momentarily And Then Would Continue Running With Loss Of Power Especially When Going Uphill Or When...
Asked by
Freapah
2 IMAGES
1999
FORD CONTOUR
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
