1997 Ford Contour Intake Manifold
860,000 MILES • 4 CYL • FWD • AUTOMATIC
AUTOMAN8260
Engine runs rough. Especially when cold. checked vacuum, no vacuum at manifold. Guessing either gaskets or since it's plastic, maybe cracked. A lot of work involved so I want to be sure. Any ideas?
Apr 13, 2008 at 1:09 PM
BLACKOP555
  • 10,386 POSTS
i would suspect a vaccum leak since there is absolutely none at the manifold?
try attaching it to another hose and see.
take a can of carb cleaner and start the vehicle and spray around the manifolds gasket and throttle bod and manifold itself, idle should increase if theres a leak.
Apr 14, 2008 at 2:13 AM
