1997 Ford Contour error codes
150,000 MILES • 4 CYL • FWD • AUTOMATIC
RESTLESS777
P1130 Lack Of HO2S-11, Fuel Trim At Limit what is this and also what is code po102
replaced air filter,spark plugs and wires, pvc valve, fuel filter, the out oxygen sensor, what else is wrong these are the codes po135, p1130, p1131, po304, po171, po102
Aug 1, 2008 at 11:45 AM
BMRFIXIT
  • 19,053 POSTS
i would check for vacuum leaks
ALSO
check and or replace mass air flow sensor
Aug 4, 2008 at 10:43 AM
