1997 Ford Contour Engine runs good, will not idle unless ga
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCOTTNEFF
Engine starts and runs like a champ. Let off the gas pedal though and it passes right thru the idle speed and stall out. Must hold gas pedal down abit to keep engine running. R & R the Throttle Position Sensor, problem still exists. Check engine light on. Any thoughts? Car was free, and is an "airport" car, so no desire to spend lots of money on it.
May 8, 2008 at 9:05 AM
  • 75,988 POSTS
You need to have the computer scanned for code/s to find out what's causing the problem-Go to Autozone they'll do it for free
May 8, 2008 at 9:12 AM
