1997 Ford Contour Engine Noise Coming from Top End
160,000 MILES • 4 CYL • FWD • AUTOMATIC
VPEDWARDS
  • 10 POSTS
This zetek engine makes an awful lot of lifter noise. How do I tell if they are pumping up? If they are working properly is there a shim that can be installed to take up any play? What else could make such a racket and still allow the car to run great?
Thanks,
Vince
Yes, I was out taking pictures of boats that day.[img:ccff2c1139]http://www.2carpros.com/forum/automotive_pictures/581064_Boat_for_Sale_2.jpg[/img:ccff2c1139][img]
Oct 8, 2010 at 6:54 AM
MMPRINCE4000
  • 8,548 POSTS
The first thing to check is the oil level and condition of oil, if black and sludgey, then you may have a galley blocked.
Hydraulic lifters use engine oil to pump up.
How often do you change oil?
Oct 11, 2010 at 2:45 AM
