1997 Ford Contour daytime runing lights
ROVER15
Electrical problem
1997 Ford Contour Two Wheel Drive Automatic
hey i'm having problems getting my daytime running lights to stay off once i turn off the car right now i have the battery disconnected so it won't die on me .... the car has been sitting for 6 months and i just pulled it out and charged the battery had it running for a hour well i got it running but i need to know what to do about the day time running lights
Mar 15, 2009 at 7:34 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect a bad battery
and should have it checked ,tested or replaced
pull fuse #4
or pull DRL relay
or try and pull the E. brakes on
if you do one of the above lights should go out
Mar 16, 2009 at 12:52 PM
