1997 Ford Contour coolant backing up into the reservoir
1997 FORD CONTOUR
150,000 MILES • 4 CYL • FWD • AUTOMATIC
RANIMAL8
Recently I have changed the thermostat, bypass hose, a heater hose and flushed my coolant. My car is still leaking fluid, but I don't see it coming from any where but the reservoir thru the pop-off valve in the cap. The level in the reservoir is fine but after I run the car for a while it backs it all up in to the reservoir. Could this be because the water pump isn't working properly? Plus I have looked for the water pump and cannot locate it on this particular vehicle, so I can't check the weep hole, could you please point it out for me and how to get to it? Thanks, Randy
May 8, 2010 at 12:10 PM
  • 110,244 POSTS
When the engine is cold, does the coolant blow into the overflow? As far as the water pump, here is a picture:
https://images.2carpros.com/forum/automotive_pictures/249084_1_3.jpg
May 8, 2010 at 12:45 PM
