1997 Ford Contour brake lights
215,000 MILES • 4 CYL • 2WD • AUTOMATIC
JP4PERKINS
I have a 1997 ford contour. Brake lights do not work . The 3rd light in the back window does work just not the tail lights. Fuses are fine, bulbs have been replaces. The night driving lights do work. What can be causing this problem?
Aug 18, 2009 at 8:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
Suspect a faulty brake lamp switch. Switch controls lower two brake lamps while a separate relay controls the high-mount lamp. Switch is located on brake pedal arm , under driver dash.
Aug 18, 2009 at 11:05 AM
