Battery Drain
1997 FORD CONTOUR
JON24JAI
Electrical problem
1997 Ford Contour 4 cyl Front Wheel Drive Automatic
My Battery has been draining after 3 days---i had my alternator changed a week ago---i also changed my battery after my alternator had been changed---after 3 days of driving my car dies---during the 3 days of driving my car drives perfectly fine
Jun 25, 2010 at 1:07 AM
It sounds like you may have a CD stuck in the player which will drain the battery here is a guide that will help us see everything it could be so you can check it out.
https://www.2carpros.com/articles/car-battery-dead-overnight
Cheers
Jun 25, 2010 at 1:31 AM
MAHENDRA DAHYA
Thanks for the guide I found the glove box light is staying on because the switch broke. Thanks for the guide helped a bunch.
May 14, 2018 at 12:32 PM
