1997 Ford Contour ALTERNATOR
107,000 MILES • 4 CYL • FWD • AUTOMATIC
DDEVAULT
HOW DO I REMOVE THE ALTERNATOR. FROM THE BOTTOM?.
Nov 16, 2008 at 12:18 PM
IMPALASS
  • 3,112 POSTS
Hello I have provided the info on removal and replacement. REMOVAL
https://images.2carpros.com/forum/automotive_pictures/248015_1_36.gif
Disconnect the battery ground cable.
https://images.2carpros.com/forum/automotive_pictures/248015_2_42.gif
Remove the intake air resonator. Disconnect the air cleaner outlet tube. Remove the bolts and nuts. Remove the resonator. Disconnect the vacuum pipe underneath.
https://images.2carpros.com/forum/automotive_pictures/248015_3_31.gif
Disconnect the generator wiring. Remove the nut and disconnect the cable. Disconnect the electrical connectors.
https://images.2carpros.com/forum/automotive_pictures/248015_4_22.gif
Disconnect the ground cable. Raise and support the vehicle.
https://images.2carpros.com/forum/automotive_pictures/248015_5_16.gif
Remove the radiator splash shield. Remove the right, front wheel.
https://images.2carpros.com/forum/automotive_pictures/248015_6_15.gif
Remove the splash shield. Remove the bolts. Remove the splash shield. Remove the accessory drive belt.
https://images.2carpros.com/forum/automotive_pictures/248015_7_7.gif
NOTE: The lower bolt cannot be removed until the generator is repositioned. Remove the generator lower retaining bolts. Lower the vehicle.
https://images.2carpros.com/forum/automotive_pictures/248015_8_8.gif
Remove the generator upper retaining bolt.
https://images.2carpros.com/forum/automotive_pictures/248015_9_7.gif
Lift the generator clear of the engine. CAUTION: There is a very limited amount of space in which to remove the generator. Do not overstress or damage any hoses or cables.
https://images.2carpros.com/forum/automotive_pictures/248015_10_6.gif
https://images.2carpros.com/forum/automotive_pictures/248015_11_6.gif
https://images.2carpros.com/forum/automotive_pictures/248015_12_5.gif
INSTALLATION To install, reverse the removal procedure.
Nov 16, 2008 at 12:34 PM
