Air only comes out defroster vents. Replaced white plastic blend control unit on right side under dash, to no avail. I think the selector switch is ok as it goes off in center position. What else could it be? Vacuum is present just above the blend control, but it doesn't move when removed and plugged in.
Nov 15, 2009 at 7:48 PM
