1996 Ford Contour timing
BBOPSCH
Engine Mechanical problem
1996 Ford Contour 4 cyl Front Wheel Drive Automatic
i need to know the camshaft positions as in which side needs to be opening and which side need to be closing when i have number one cylinder at tdc ,i know they say you need there tool to lock the cams but i can get around that any info you can give me would be very helpful ,i can use the slots for there tool to align the cams just need to know which one is opening and which one is closing,the ford tech i talked to says both should be closing but to me this sounds wrong ,please help me
Jan 30, 2009 at 3:29 AM
BILLYMAC
  • 2,204 POSTS
if you line the slots and lock cams on tdc it will be right. the other ford tech is right. compression all valves have to be closed on that cyl. billymac
Jan 30, 2009 at 3:36 AM
