1996 Ford Contour odometer
69,000 MILES • 4 CYL • 2WD • AUTOMATIC
KAGEJD
  • 6 POSTS
I just bought a 96 contour. The speedometer (mechanical not digital) works fine but the odometer doesn't at all.
What might be causing it? I thought both gauges ran off of the same cable that is connected to the transmission.
Any insight would be appreciated. Thank you.
Oct 15, 2008 at 9:47 AM
DOCFIXIT
  • 18,828 POSTS
Speedo is bad small plastic gear is spinning freely on its shaft.
Oct 15, 2008 at 10:05 AM
