1996 Ford Contour No spark
195,000 MILES • 4 CYL • FWD • MANUAL
CARJUNKIE2010
replaced every sensor everything is getting power tested and checked all fuses and wiring will not get spark just replaced motor new coil pack and plugs help me
Apr 10, 2010 at 10:59 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Apr 11, 2010 at 6:39 PM
