1996 Ford Contour IDLE
151,000 MILES • 4 CYL • 2WD • MANUAL
KEVIN RAY
I BELIVEVE I CANT PASS A SMOG TEST BECAUSE OF MY IDLE --- THE ENGINE GO'S UP AND DOWN LIKE THERE IS SOMETHING OUT OF CONTROL WITH THE ENGINE WHEN I'M AT THE LIGHT ---- HOW CAN I FIX THE PROBLEM OR HOW MUCH WILL IT COST FOR ME TO GET THE IDLE FIXED SO I CAN PASS SMOG
Feb 1, 2009 at 2:31 AM
BMRFIXIT
  • 19,053 POSTS
do u have a check engine light on
andif so check for codes and let me know what you have
check for vacuum leaks check PCV valve and hoses
Feb 1, 2009 at 10:39 PM
