Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Contour
Engine
Symptoms
Runs Hot
1996 Ford Contour fan motor
1996 FORD CONTOUR
127,000 MILES • 4 CYL • FWD • AUTOMATIC
ZEDEMAUL48
MEMBER
engines runs hot
Feb 25, 2010 at 4:54 AM
BLUELIGHTNIN6
Experienced Mechanic
check coolant level. are cooling fans coming on?
Feb 25, 2010 at 5:19 AM
ZEDEMAUL48
MEMBER
fan run if relay is manually pressed so I replaced the relay and it does not run either
Mar 5, 2010 at 3:46 AM
BLUELIGHTNIN6
check for faulty engine coolant temp. (ECT) sensor
Mar 7, 2010 at 8:42 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
