Original engine overheated, purchased salvaged engine and installed over Labor Day
Installed several new parts like timing belt, water pump, radiator, etc.
Put old flywheel on replacement engine.
Repaired insulation on several wires coming across top of radiator
Engine will turn over, but not start
Had to replace crankshaft sensor plug with best available fit from junkyard
Power is present at coil pack, fuel rail, and crankshaft sensor
Have fuel pressure, but no injection, also no spark at plugs
Swapped old crankshaft sensor, no help
No codes indicated on analyzer
SPONSORED LINKS
Friday, September 11th, 2009 AT 3:22 PM
