1996 Ford Contour Defrost/ Air conditioning
1996 FORD CONTOUR
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROBERTBLY
How can I easily and safely disconnect the air conditioning so it doesn't turn on when I use the defroster. I want to be able to easily reconnect it so I can use the A/C during peak-heat summer. Thanks!
Oct 15, 2009 at 3:37 PM
FIXITMR
  • 9,990 POSTS
possibly a fuse or pull the plug on the compressor or the freon pressure sensor .
Oct 19, 2009 at 12:56 PM
