1996 Ford Contour Car Will Not Idle
15,500 MILES • 4 CYL • FWD • AUTOMATIC
NICK_HOFFERT
When i start my car if i do not press any force on the gas pedal it will sputter and die immediately. it only idles after about 20 mins of constant drive time and while idling sputters. what can i do to fix this problem?
May 20, 2010 at 8:02 AM
  • 75,988 POSTS
Try cleaning the idle air control valve, Mass airflow sensor,EGR/PCV valves and test the throttle position sensor.
May 20, 2010 at 8:06 AM
