1996 Ford Contour CANT TELL IS TRANSMISSION IS BAD OR TORQU
130,000 MILES • 4 CYL • FWD • AUTOMATIC
DEBJAMES
MY CARS OVERDRIVE IS BLINKING AND WHEN I DRIVE IT,IT WONT GO INTO GEARS RIGHT AWAY AND I WAS TOLD IT WAS THE TRANSMISSION BY A MECHANIC BUT TOLD IT MAY BE A TORQUE CONVERTER BY SOMEONE ELSE. I CANT TELL WHICH ONE IT IS
Jan 31, 2008 at 12:24 PM
MASTERTECHTIM
  • 4,750 POSTS
first of all we need to find out what codes your transmission has. they will be stored in memory. unfortunately you will have to bring it to a repair shop to do that.
Jan 31, 2008 at 12:47 PM
DEBJAMES
is there any signs that each will show when they are going??? my cars overdrive light is blinking and when i drive the car feels and sounds almost as if it were in neautral but than it will kick in and feel fine.... are those signs leaning towards transmission or torque converter?
Jan 31, 2008 at 1:18 PM
MASTERTECHTIM
  • 4,750 POSTS
well with the light flashing im thinking more of a shift solenoid or pressure switch
Feb 1, 2008 at 9:51 AM
