1996 Ford Contour brakes makes grinding sound
198,000 MILES • 4 CYL • FWD • AUTOMATIC
LAWRENCELS427
my front driver side brake sounds like it is grinding but the brakes look good the peddel pusates and clicks, i loose fluit. ti sounds like the studs are digging in the roters but they look ok
Dec 23, 2008 at 4:56 AM
  • 110,248 POSTS
Does the sound only happen when you use your brakes?
Jan 2, 2009 at 2:48 AM
