1996 Ford Contour belt tensioner
STR8BALLIN
Engine Mechanical problem
1996 Ford Contour 4 cyl Front Wheel Drive Automatic
my car vibrates when I come to a stop in gear but at idle in park or neutral its fine.I can see my tensioner shake while in gear and cause the vibration.All that play means its fixen break soon.Thats all I can figure that could possibly be wrong.whats your opinion?
Oct 8, 2008 at 1:48 PM
BMRFIXIT
  • 19,053 POSTS
Check pcv valve and it hose for leaks
check for vacuum leaks
check and clean idle air control valve
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 15, 2008 at 1:35 PM
