1996 Ford Contour Absolutely no power
143,000 MILES • 4 CYL • FWD • AUTOMATIC
JIMBODADDYO
I sure hope some one can help. I'm out of ideas.
I bought this car for my daughter. It was not running at the time. I found the flywheel was bad and replaced it. The car ran fine for weeks. It went through inspection and emissions without a hitch.
One night coming home she noticed the car had very little power. I went to take it for a ride and there was no power to even get it out of the parking spot. The next morning I changed the fuel filter and it seemed fine till it warmed up and once again no power. I removed the cat for inspection because the computer tester said catalyst problem. With the cat off the car I tried the car and still no power once the engine started to warm up.
The car is hard to start now but will stay running once started. I also noticed the temperature gage goes a little higher than it used to. Like a lean running condition.
I'm at witts end and looking for some help.
Feb 22, 2009 at 2:53 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:3ab1071c1c="jimbodaddyo"]Engine Performance problem
1996 Ford Contour 4 cyl Front Wheel Drive Automatic 143000 miles
I'm at witts end and looking for some help.[/quote:3ab1071c1c]
Check out the link below for more thing to check....
https://www.2carpros.com/first_things/why_does_my_engine_have_low_power.htm
Feb 22, 2009 at 3:22 AM
