1995 Ford Contour Vibration on motor
11,800 MILES • 4 CYL • 2WD • AUTOMATIC
TONY_54
When car is in gear the motor shakes or vibrates.
When you turn the stering wheel the car shakes more.
when car is in neutral or park the vibration seem to be less.
thanks Tony
Apr 30, 2009 at 12:37 PM
  • 75,988 POSTS
Check the engine and transmission mounts
Apr 30, 2009 at 1:02 PM
SUPERJVC
this is common on these cars. the motor mounts are tampered with rubber spacers. they get worn out and flatten out. you can change them but its a difficult fix. Best just to live with it.
May 17, 2009 at 2:57 AM
